Is there a way so I can record on virtual DJ LE?
geposted Tue 23 Apr 13 @ 7:15 pm
Yes, recording is available in the Limited Editions. Open the RECORD tab of the BROWSER and choose to START.
It is limited to record a specific filename/filepath in wav format. If not mistaken it should be saved in the MyDocuments\VirtualDJ folder.
More Record options (mp3 format, choosing the path and the filename, split files, etc) are available in the Pro Full version, which you can purchase at a discount... https://virtualdj.com/products/oem.html
geposted Tue 23 Apr 13 @ 9:03 pm
