hey, say its the last bit of your set and your running tracks off both cdjs. is there a way to disconnect both cdjs whlie letting the tracks play out thru just vdj? it be helpful for swapping out, i know traktor has an option to just switch to cpu or internal or something like that. thanks
geposted Fri 26 Apr 13 @ 2:31 pm
Are you talking about CDJs as MIDI/HID controllers, or CDJs controlling Virtualdj by timecode vinyl/CD?
geposted Sat 27 Apr 13 @ 12:38 am
good call, im talking about cdjs or turntables with timecode vinyl/cds thanks
geposted Sat 27 Apr 13 @ 12:23 pm
If you disconnect the cdj or turntable you disconnect the timecode, you disconnect the timecode, you disconnect the music. If you disconnect the music, you disconnect from the party. If you disconnect from the party, you just disconnected in genreal.
Bottom line... Dont disconnect your cdj's or turntables While You Are Playing!
Hope this helps.
Hope this helps.
geposted Sun 28 Apr 13 @ 10:32 pm
I bet he's feeling disconnected now!
I just had a thought: Why not play your last track from a sampler slot, or a third VDJ deck?
geposted Mon 29 Apr 13 @ 10:26 am
Her wants to know if He can play a song in Internal mode like Serato but, with Virtual DJ. In Internal Mode, You can disconnect a CDJ or a Turntable and have the song playing on its own.
geposted Mon 29 Apr 13 @ 6:53 pm
do u mean swapping dj sets from vdj to someone else using the cdj's or from one lappy to another?
geposted Mon 29 Apr 13 @ 9:24 pm
ya calientes got it. im running cdjs with timecodes and then next man is running tech 12s. if vdj could go internal like serrato or traktor, than i can make my last mix, go internal, and pull the cdjs, and while the tracks finish the tech 12s are getting placed. is it possible on vdj?
geposted Fri 03 May 13 @ 10:28 pm
@highten
I believe he told you that already, but if you need the 411 on that, ask him to share?
geposted Sat 04 May 13 @ 10:27 am
I'm gonna assume your using a soundcard other then your cdjs, if so you just switch one deck at a time. We do it all the with turntables, heck we evenevenswap out soundcards and laptop.
All you should need to do is pull the inputs (cd input) on one deck then plug in the turntable. Rinse and repeat for the other side and you should never have to stop the music......
geposted Sat 04 May 13 @ 11:48 am
JoeyKJ wrote :
@highten
either i am misunderstanding that qoute or I think you have taken it out of context. i believe when caliente refers to internal mode, it is in serrato not vdj?
geposted Sun 05 May 13 @ 2:56 pm
yes for sure beatbreaker, that would be the norm. the scenario came up when running both decks to the end of the set. cant disconnect one without losing sound. the next man up had traktor, he started on internal, then we then swapped in turntables.
geposted Sun 05 May 13 @ 3:02 pm
and yes for sure, both with external sound cards
geposted Sun 05 May 13 @ 3:04 pm
