I'm using a Novation Twitch and when I set an auto loop to mix out of I can't sync to it from a hot cue button I have assigned. It always comes in on the half beat. If I use the play button instead from the hot cue point I have set it syncs fine. Just not from the assigned button. I have tried disabling key lock, pitch lock and smart play. It makes no difference.
Any ideas?
EDIT: It only seems to do it at the end of this track I was using for testing. I moved back into the track a bit and it works fine. For some reason VDJ is not able to fathom where the auto loop begins and ends and throws the hot cue in at a half beat instead. Weird.
Any ideas?
geposted Fri 26 Apr 13 @ 4:45 pm
