the tpis doesn't shows when the Mouse cursor is on somting and it is enabled on the options (i need it for the jog Sensitivity To see the percentages)
Secondly on the sound setup in external mixer i pick: deck 1 3&4 deck 2 1&2 so the sound will be on the right side on the mixer (i use a usb hub) but if i enter the config While the music plays And click on any tab it goes It's automatically returns to default and the sound goes...
MBP 13 I7 10.7.5
cdj 400
MBP 13 I7 10.7.5
cdj 400
geposted Tue 30 Apr 13 @ 6:08 pm
Any ideas ?
geposted Tue 07 May 13 @ 12:17 am
I have a old sound card that did that when I set the setting it work Ok but when I re-open the setting it goes back to def,do re-open the setting after you set it.or something Diff?
geposted Wed 08 May 13 @ 6:56 pm
