I noticed theres a HID mapper for the NI KONTROL S2, but I dont see one for the S4. Is there one available?
geposted Thu 02 May 13 @ 2:13 am
The MIDI Implemantation of the S4 is unusable. the Jogwheels send about 64 impulses on 1 turn (or 128 ? anyway).
A normal MIDI Jog sends about 3500 pulses on 1 turn. So the MIDI Implementation of the S4 sucks.
Greets,
Phillip
Greets,
Phillip
geposted Thu 02 May 13 @ 2:32 am
Greets,
Phillip
Greets,
Phillip
you obviously havent done very much work with the S4, the jog wheels can be modified to send a higher amount of MIDI ticks.
unfortunately the S4 doesnt send any HID, only NHL so until i can find a way to extract the raw data from the NHL, we are stuck with MIDI
geposted Thu 02 May 13 @ 4:23 pm
Could you please explain how you changed this value ? s it possible to get 3500 pulses like with every other MIDI controller, too ?
Greets,
Phillip
Greets,
Phillip
geposted Fri 03 May 13 @ 12:24 am
if i remember correctly you can modify the ncc file to set the mapper to report more ticks
geposted Fri 03 May 13 @ 12:48 am
