Forum: Old versions
Topic: compatibity between VDJ versions, 7.0.5
Hi
running mac 10.6.8, vdj 7.0.5, denon mc6000
all stable.
Thinking about upgrade vdj software to 7.4.
Is ist possible to downgrade to 7.0.5 after the upgrade ? If "something" goes wrong.
regards
Steen
geposted Sun 12 May 13 @ 2:47 pm
Yes, you can simply install v7.05 again over the top of v7.4
Alternatively (Recommended), make a copy of the VirtualDJ Pro application and rename it VirtualDJ Pro v705 - Then when you install v7.4, you will get a new application icon for it and can then run either by clicking on its icon.
Make sure that you take a full backup first before upgrading (See https://virtualdj.com/wiki/How%20do%20I%20backup%20my%20VirtualDJ%20database%20and%20settings.html ) and ensure that you have plenty of time to test it (Don't upgrade just prior to going to a gig.)
