Hello,I have a Question
when Ever i put in a Mapping for my Keyboard it does not work!!!
i Put Key (z) Mapping/Action eq_crossfader_mid and it doesnt work when i hit ok
Please answer this i want to Cut and Scratch and if you do answer my Question Many Thanks!!
geposted Sun 12 May 13 @ 9:13 pm
if you are going to map 'eq_crossfader_mid' you need to give it a modifier so it moves the fader, as that script is meant for a CC knob/slider
eg. incremental
eq_crossfader_mid +1%
eq_crossfader_mid -1%
eg. absolute
eq_crossfader_mid 0%
eq_crossfader_mid 50%
eq_crossfader_mid 100%
eg. while_pressed
eq_crossfader_mid 100% while_pressed
eg. smart
deck left select ? eq_crossfader_mid -1% : eq_crossfader_mid +1%
eg. smart absolute
down ? deck left select ? eq_crossfader_mid 0% : eq_crossfader_mid 100% : eq_crossfader_mid 50%
the incremental scripts will only work properly on your computer keyboard not a controller
eg. incremental
eg. absolute
eg. while_pressed
eg. smart
eg. smart absolute
geposted Mon 13 May 13 @ 12:00 am
Ok thanks man !! :D
geposted Mon 13 May 13 @ 5:08 pm
