Hi thanks for reading, I have just got my friends old VSM 4, as far as i know i have it set up properly but unfortunately channel 3 (second from right) fader is broken so i was wondering how i change it so that the farthest left fader controls 1 and the farthest right controls deck two on VDJ7
any help would be massively appreciated thank you
geposted Mon 13 May 13 @ 4:46 pm
in the front you'll need to adjust for A and B aka Left and Right to the correct midi logs (1 & 4) for the crossfader, and you'll need to switch 1 & 4 to USB, 2&3 to analog. 4 in 4 out. and in VDJ you'll need to set it to LEFT & RIGHT, or decks 3 & 4. i think this should work
or take the unit apart and replace the channel 3 fader, but whatever you want to do i guess.
geposted Mon 13 May 13 @ 6:35 pm
Would you be able to tell me what all the setting should be? im really struggling with this.
thank you
thank you
geposted Wed 15 May 13 @ 12:21 pm
I thought that's what I did?
geposted Wed 15 May 13 @ 11:17 pm
