Hey guys....
Looking for a plugin that will shuffle or randomly pic a pic when using a slidshow plugin. Have been looking on the forum but did not see one, maybe I'm not looking in the right place?
THANKS
THANKS
geposted Tue 14 May 13 @ 9:56 am
Pretty sure that doesn't exist, but you could always ask someone to make one. I'd use it if it existed.
geposted Wed 15 May 13 @ 11:47 pm
Essential Media 2.5 can do a variety of images types but it uses the media items stored in a pak file and not directly off of disk drive yet.
pak files can contain up to 48 images, video, or audio files and they can be loaded at any time. I think you are talking about a slide show from folder which I have not gotten around to. You need to create a pak file by drag/dropping the images on to EM that you want to use. You can create as many pak files as you want.
After pak is created, you can choose to run it manually, sequentially, or randomly. It will run as a automated slide show in sequential or random mode. Works with audio, video, or image files and any combination of.
Supported image types include gif, animated gif, png, animated png, bmp, jpeg, targa, tif, emf, wmf, and more.
EM 2.5 will be up soon.
geposted Thu 16 May 13 @ 12:44 am
I don't remember which Windows OS version for the picture viewer I used before (might be XP).
But I remember there was one that I used and had an option to RAMDOMIZE the slide show with Transition Effect like Fade.
This might just work out for you at the moment until something comes along (VDJ Plugin wise).
geposted Thu 16 May 13 @ 8:23 am
I just tried on my other PC with XP, it's not XP. So, it might have been Win98.
It was a long time ago.
geposted Thu 16 May 13 @ 8:33 am
Im on Win8 now and tried the Viewer, it does RAMDOM slideshow but no effects. Maybe that's good enough for you. I don't know if you can throw the display on a second monitor.
geposted Thu 16 May 13 @ 8:43 am
When I run picture slideshows I simply use Windows desktop slideshow feature. Unfortunately if you load a video or clipbank you can't go back to it without restarting VDJ, but it has worked for me;^]
geposted Thu 16 May 13 @ 10:08 am
This feature has been available in Firetext admin for some years now, you can use png, jpeg etc.
geposted Thu 16 May 13 @ 12:16 pm
Do you have to pay for firetext to have this feature?
geposted Thu 16 May 13 @ 1:49 pm
This is what you get with the free Firetext plugin... available only to VDJ Pro users.
Once you have the new plugin installed you will have all these features to run through VDJ…
* 1,000 unique users
* Sms to screen
* Tweets to screen
* Emails to screen
* Choice of horizontal or vertical text scroller
* Image slide show (show your company logo or run adverts for venue)
* Multiple Image slide show (Adrotator) with timed pause and play functions
* Camera or External source tab, Picture in Picture facility, great if you want to show a sports event on screen whilst still having the ability to run music videos and other effects on screen at the same time.
* Movie tab, run your own custom made video logo’s and on screen adverts/promotions or party wishes with this
* All of the above can be made to any size and placed anywhere on screen
* Template save tab, once you have set your logo’s/advert and anything else up on screen use this tab for future reference for your next shows
* Alpha blend of text and images (transparency)
* Control location maintain aspect
* Chromakey advanced filter
* Free of any on screen advertising
* No time limit to its use
Extras
* Text to screen sourced from Firetext Administrator
* Random and paused image rotation from Firetext Administrator
* AVI/MPG/SWF movies sourced from Firetext Administrator
* Twitter client for screen name replies shown as normal messages
* Sms to screen
* Tweets to screen
* Emails to screen
Extras
geposted Thu 16 May 13 @ 3:26 pm
Thanks Tayla have to try it out. Remembered downloading it and seeing that it cost and was waiting for a special event to try it out. Had forgotten about it.
geposted Thu 16 May 13 @ 11:31 pm
wizsax wrote :
Hey guys....
THANKS
THANKS
the feature your asking for VDJ has that just open VDj go to effects then copy slideshow then paste rename slideshow 2,set of folder with your pic in I just have about 30 pic or less in each folder so VDj can make a smooth Delay to the next pic And Pangolin I use it with LIVE texting( see & say ) at my sunday gig and they LOVE it,ck the Download page and plugins and try some.
geposted Fri 17 May 13 @ 9:55 am
He needs random choice do the others have that, if they do he's spoilt for choice then.
geposted Fri 17 May 13 @ 12:06 pm
Essential Media has the ability to do automatic random or sequential, or manual selection. The current EM allows for video, CDG, and SWF files. EM 2.5 which is due to be up any day now, also allows for any type of image and audio only files. Any of these can mixed or matched. You can save and load pak files at any time. EM handles any kind of audio format with up to 8 channels. All channels are converted accurately to stereo if need be.
EM 2.5 transitions include no transition, fade separately, and crossfade. These transitions work for all audio and video. So audio will fade in and out as well as video. The transition type is saved with a pak file so different paks can have different transitions. The transition type can be changed at any time.
I don't believe there is any other program on any platform that can playback as many media formats as EM 2.5 can.
geposted Fri 17 May 13 @ 4:00 pm
I did not find the rotation / random option THX!
geposted Tue 21 May 13 @ 11:11 am
On the Media tab in Essential Media, you can select Autoplay, Random, or Manual. Its called Movies tab on older version. Media tab on EM 2.5
Autoplay plays thru the pak sequentially
Random plays the pak files randomly.
email me if you want to try an EM 2.5 beta but autoplay and random are available on older versions as well. EM 2.5 add images and audio only files to the mix.
donmoir@comcast.net
donmoir@comcast.net
geposted Tue 21 May 13 @ 8:38 pm
