Guys,
I bought controller DDJ-SX and I would like to know, if somebody are using with virtual dj. I would like to know if all the buttons function normally.
BR
Max
BR
Max
geposted Tue 14 May 13 @ 1:26 pm
Pioneer DDJ-SX is natively supported. https://virtualdj.com/wiki/VirtualDJ%20Controllers.html
Everything works 100% (buttons, jogs, leds etc. Lot of users are already using that device without issues.
You can download the Home Free version and test the unit for 10 minutes each time you re-start the software as demo, prior purchasing Pro Full version.
geposted Tue 14 May 13 @ 1:35 pm
I tested yesterday and no function all the buttons and I didin't find skin of DDJ-SX.
geposted Wed 15 May 13 @ 6:38 am
The latest VirtualDJ v7.4 is required - Older versions do not have any native support for the DDJ-SX.
Please download the latest VirtualDJ Home FREE v7.4 to test for 10 minutes at a time: https://virtualdj.com/download/free.html - Once you have finished testing, you will need to purchase the full VirtualDJ Professional to continue using it: https://virtualdj.com/buy/
Make sure that the drivers and firmware for the DDJ-SX are also fully up-to-date.
A DDJ-SX skin is not required to use the DDJ-SX. The skin has no effect on the functionality of the DDJ-SX and vice-versa.
However, there are custom skins that you can optionally download once you purchase the software: https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=all&search=ddj
geposted Wed 15 May 13 @ 6:54 am
I have one question yet. I would like to know if I'll buy this software, how many computers I'll be able to install this software. I ask because I have 3 computers.
geposted Wed 15 May 13 @ 3:37 pm
geposted Wed 15 May 13 @ 4:02 pm
You can install on two computers, one for your gig rig and one for your backup rig, but if one of those crash and you need to re-install, you shouldn't have any problems doing so... And if there is an issue for any reason the good folks at VDJ will help you... (:
