Hello,
So I used to use a pair of small computer speakers. Now I moved to a bigger house where have enough space to plug both my main tops(dont own subs yet). Would you guys suggest using? Wondering how long my 15s would last?
What would you do would you use you're main speakers just to practice at home?
geposted Wed 15 May 13 @ 3:39 pm
I wouldn't use PA speakers for monitoring at home.
The tweeters used by PA speakers are completely different to what you'd get on studio monitors or hifi speakers.
You'll get a harsh top end sound from PA cabs, but a nice smooth soft sound from hifi or monitor speakers.
Get yourself some KRK Rokits!
geposted Wed 15 May 13 @ 6:40 pm
If you are practicing at home, Any pair of speakers will do. Studio monitors, Home theatre speakers, DJ speakers, etc.. It doesn't matter because all you are doing is just practicing your blends and making mixes. You are not producing music in a studio. I use two stageworks Powered 6 inch speakers and 1 Jbl 10 inch home theatre powered sub. Years Ago, I use to use Bose 301 speakers with a receiver, Boss portable powered guitar speaker, Gemsound Speakers, Fisher Home stereo speakers, JBL control speakers etc. It didn't make a difference for me. I was able to monitor my music so I can make some nice tapes.
geposted Wed 15 May 13 @ 9:39 pm
Practicing on studio monitors is the best in my opinion. If you can't hear a flaw in your mix on the studio's, then you'll never hear it on a PA system. Studio monitors are made to be extremely accurate and neutral. They'll show every flaw in a track or mix. Sometimes a mix that sounds awesome in the club will sound like crap on studio's. I feel like my Yamaha HS80M's have really help me tighten up my mixes.
geposted Wed 15 May 13 @ 11:43 pm
+1
Valid point!
geposted Thu 16 May 13 @ 10:43 am
I have these cheapo speaker system that actually sounds amazing. Got em all at parts express. For a small bedroom where I have my "studio" this is plenty.
The Mini Amp. Great for a small room
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-383
The speakers:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-652
The Sub:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
Cost: under $300 with cables and speaker wires.
The speakers:
The Sub:
geposted Thu 16 May 13 @ 12:59 pm
Hmm...I did not know that about studio monitors! Thanks for the input guys!
geposted Fri 17 May 13 @ 5:03 pm
Same thing goes for your headphones when mixing at gigs. Thats why pro dj headphones are so expensive. That being said I use the Denon dnhp1000's. Their a lil more bassy then they should be, but extra loud and comfortable. Cant stand the pioneers because their too tinny and they choke me when I where them around my neck.
geposted Fri 17 May 13 @ 5:22 pm
