I think we have a big problem here.. I've made the updates of my virtual dj software and 1st, I got a pop-up that says to me that vdj quit instatly and offer me to reboot. I click reboot and same s**t happen. I unnistall VDJ et re installed it. I copy-paste my serial key and it says INVALID!!! **** OFF what's that men. I need VDJ for tonight
there is the error code : http://famillebenoit.mycloudnas.com:8080/share.cgi?ssid=0srWXqi
BTW I'm on mac
[Moderated: Please DO NOT use bad language in your forum posts - Please read the forum rules]
BTW I'm on mac
geposted Thu 16 May 13 @ 10:42 am
Please perform a clean re-installation of the software, making sure that you enter the correct serial number for VirtualDJ Pro from your download center (Take care not to enter the RMX VirtualDJ LE serial number on your account - That won't work with the full Pro): https://virtualdj.com/wiki/How%20do%20I%20perform%20a%20clean%20re-installation%20of%20the%20software.html
If you still have problems, please contact support for direct assistance: https://virtualdj.com/contact/
IMPORTANT: Never update or make major changes to your computer or software just prior to going to a gig. Always wait until you have plenty of time to install and test the new version.
geposted Thu 16 May 13 @ 11:34 am
thank you for the fast reply! BTW I never have plenty times LOL. My database was corrupted... Don't know why...
It works now, thank you
PROBLEM SOLVED
PROBLEM SOLVED
geposted Thu 16 May 13 @ 12:08 pm
