I cant seen to keep sync .if I loop I lose my sync ...any help
geposted Thu 16 May 13 @ 8:39 pm
Turn on the smart loop (the small padlock next to the loop section on the default skins) or practice to be able to hit loop-in and loop-out buttons more accurately.
geposted Thu 16 May 13 @ 10:41 pm
The beat grid could be off on your track, or if you use an ns7 the platters don't spin at the same speed until the motors are warm. Use the pitch or pitch bend to keep it on.
geposted Thu 16 May 13 @ 11:11 pm
Map loop 1, 2, 4, 8, 16, 32 functions instead of using loop in/out.
geposted Fri 17 May 13 @ 3:16 am
i use the beat mix skin for the RMX i have never had a problem like this till last update . i also ues win8 now.
geposted Fri 17 May 13 @ 5:41 am
