Hi All,
I have VDJ7 Pro running on standard PC laptops, along with a Mac Mini desktop, and love it. I'm considering buying one of the new mid-priced touchscreen laptops with Windows 8. Is VDJ7 Pro compatible with the touchscreen capability? Any issues to be on the lookout for?
geposted Mon 20 May 13 @ 1:52 pm
Should work fine. The latest version now supports multitouch as well.
May be worth checking you can get a touch skin to match the screen resolution of the LCD.
https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=all&search=touch
Keith
Keith
geposted Mon 20 May 13 @ 2:07 pm
I have been running 7.4 with my Windows 8 touch Thinkpad for some time now without any issues at all. Using Hercules RMX 2.
geposted Mon 27 May 13 @ 4:37 am
so will the regular 7 pro version work on a touch screen or do i have to downlaod the touch screen skin?
thanks in advance.
i am looking into touch screen too
thanks in advance.
geposted Sun 21 Jul 13 @ 8:40 pm
Touch-screen skins are useful as they provide large buttons and sliders for easier access. The skin itself is not adding any features. Version 7.4 supports multi-touch screens, regardless of the used skin.
geposted Sun 21 Jul 13 @ 10:34 pm
