Today vdj is not recognizing my playlist I'm getting errors on every audio file any help here
geposted Thu 23 May 13 @ 9:20 am
maybe your file/folder structure has changed.
Search for the song that is in one of your playlist and load into a deck to see result.
geposted Thu 23 May 13 @ 9:45 am
Did the computer change the drive letter of your external hard drive? If it did and you remember the old drive letter, you can change it back. If that's not the issue, try this https://virtualdj.com/addons/13794/Playlist_Fixer.html
geposted Thu 23 May 13 @ 1:33 pm
My files are on my external drive they play in iTunes but will not load on vdj. I manually drag and drop my files to vdj and it's giving error
geposted Thu 23 May 13 @ 3:34 pm
I'm having the same problem and no one at virtual dj is responding to my email, calls, or chat requests
geposted Wed 03 Jul 13 @ 2:01 pm
Right click on the file that's not loading, select file info and check the path .... it shows is where the song should be.
Keith
Keith
geposted Wed 03 Jul 13 @ 2:33 pm
A complete description of the related issue and how to correct it can be found here: https://virtualdj.com/wiki/Error%20loading%20song.html
geposted Wed 03 Jul 13 @ 3:52 pm
