I have a great idea for the new version (or even the current version).
In the new version, how about a CONFIRM button when you press the RESET TO FACTORY in the Config Menu.
So that way when you go to click "Check for Update" but accidentally click "Reset to Factory" that you can catch your mistake.
geposted Sun 26 May 13 @ 10:54 am
That is a solid suggestion. Perhaps next time you have an idea that good, you should place it in the proper forum, here --> https://virtualdj.com/forums/18/Wishes_and_new_features.html
geposted Sun 26 May 13 @ 11:05 am
