Topic: ContentUnlimited - Audio
Can anyone explain the download process for content unlimited? I searched an artist, then right-clicked to download the song. The track ended up in a cache sub-folder within the Virtual DJ folder. And then the track was renamed with a series of letters and numbers, rather than the standard artist-track-format. Is anyone else experiencing this issue with track being renamed?
geposted Wed 29 May 13 @ 3:23 pm
The actual file name on disk depends on how it is named on the content provider's server. However, the file should have the correct tags embedded in it so that it displays correctly within VirtualDJ when browsing, loading it on a deck, etc. (ContentUnlimited files are DRM protected and will only work in VirtualDJ.)
NOTE: If you added the song to a playlist before downloading it, you will see it appear like this in the playlist when you next use it. ContentUnlimited files must be downloaded first before adding to a playlist (Please see https://virtualdj.com/wiki/I%20am%20unable%20to%20save%20ContentUnlimited%20songs%20in%20a%20playlist.html )
