Which VDJ version is better to use; VDJ LE or VDJ Home?
geposted Sun 02 Jun 13 @ 6:12 pm
Define "better"....
The LE version supplied with a controller is "better" than the Home version, because it allows you to use a controller.
geposted Sun 02 Jun 13 @ 6:18 pm
It depends on your needs...
https://virtualdj.com/products/comparison.html
geposted Sun 02 Jun 13 @ 6:30 pm
I have a VDJ Home edition, I can't cue up to hear music through my external mixer, what do I need to get, I also just transition to computer DJ from CDs, be gentle on me, just a novice to computer DJ
Thanks
One Love
Sean
Thanks
One Love
Sean
geposted Mon 23 Sep 13 @ 10:35 am
How are you planning to use VDJ with your external mixer?
Do you want to send the output of each VDJ deck to a separate input channel of your mixer, so you can cue on the mixer?
Check the VDJ feature comparison chart https://virtualdj.com/products/comparison.html
You can see that some versions support "master & headphone" output (cue using the software) and others support separate deck output (cue on your external mixer).
geposted Mon 23 Sep 13 @ 11:35 am
