I'm having issues with the crossfader... When the left deck plays... I can still hear it...even with the cross fader all the way to the right.... but when the right deck is playing... and not the left... if I move the cross fader to the left... I can't hear it anymore. (the way it should be) Please help... it's ANNOYING!
geposted Mon 03 Jun 13 @ 4:20 pm
to get more help you should register your copy of virtual dj
secondly, check the settings on the NS6 itself, make sure the cf knobs are set correctly and crossfader isn't reversed.
if you're still having issues, ONCE you register, dl the ns6 controller file from the download center.
if you have ANY version of serato installed, i recommened uninstalling it aswell as the drivers, this caused an issue for my friend with the NS6
geposted Mon 03 Jun 13 @ 4:27 pm
Im having this same problem with my new NS6 as well.
geposted Tue 06 Aug 13 @ 5:45 pm
