I want to make the command "deck 3 linein 'mic'" a while_pressed command but it ignores it. If I take out the 'mic' part it works fine. I am trying to make my own talkover and have almost everything else sussed out. But this one annoying thing!
Any way to do it???
EDIT: Got some help. This works on a button and can be customized to however you need it. I have a crappy mic with no top cut so adapted it to have more push.
down ? deck 3 gain_slider +0.5 & deck 3 linein 'mic' & holding & deck 1 volume 50% & deck 2 volume 50% & deck 4 volume 50% & deck 3 eq_high 100% & deck 3 eq_mid 100% : deck 3 linein 'mic' off & mic off & deck 1 volume 100% & deck 2 volume 100% & deck 4 volume 100% & deck 3 eq_high 50% & deck 3 eq_mid 50% & deck 3 gain_slider -0.5
Any way to do it???
geposted Mon 03 Jun 13 @ 4:40 pm
