I searched and found some discussion about this, but they were old threads and answered based on previous versions.
Is there a way in vdj 7.4 to mark certain cue points differently?
I'd like to mark cues with some way to visually determine if they're an Intro, Outro, Verse, Chorus, Hot Cue, etc...
Color coded would be awesome.
If you can't do this at the point of setting cue could there be a way to say set colors for a range of cues via the xml file?
1-10 - blue
11-20 - red
21-30 - yellow
31-40 - white
or whatever color format suits you.
Or even use a different marker (triangle) in the wave form? Currently there is an inverted triangle as the cue marker.
So you have this \/
If we could create another for variations like /\ , > & < .
1-10 - blue
11-20 - red
21-30 - yellow
31-40 - white
So you have this \/
geposted Tue 04 Jun 13 @ 10:49 am
The only way to make your Cue points to differ is to provide Names to them, using the cue_name action and skins that show Cue Names
geposted Tue 04 Jun 13 @ 7:46 pm
Is it possible to change the background color where the text is displayed for the cue marker?
geposted Wed 05 Jun 13 @ 8:18 am
