Forum: Old versions
Topic: EQ Mapping?
Hi!
I am really struggling with the keyboard mapping in the config menu!
I have a controller (Numark DJ2GO) which has no eq controls, and i want to be able to adjust the low eq with a keystroke!
Can anyone please help!
Cheers
DJ_J@DC
geposted Wed 05 Jun 13 @ 9:43 am
you need 12 keys, then map the following
deck left eq_high -1
deck left eq_high +1
deck left eq_mid -1
deck left eq_mid +1
deck left eq_low -1
deck left eq_low +1
then do the same for the right deck eg. deck right eq_high +1 etc..
Please be aware that VirtualDJ LE is free limited software does not support mapping keyboard shortcuts except during the 20 day trial of the full VirtualDJ Professional. Once the trial expires, the shortcuts will no-longer work.
To be able to customise the keyboard shortcuts, controller mappings and much, much more, you will need to upgrade to the full VirtualDJ Professional: https://virtualdj.com/buy/
