Hi Guys
Pls help me here
im trying to broadcast with virtual dj ,my set up is numark v7 pair and ps-01Gemini mixer when i ligne up the next track you can hear on the radio , basicly i dont have two seperate channels when try to mix ,that mean i have turn the volume down manualy on the software and the mixer not linked
i hope i explained this proppely
pls help if anyone knows how
thanks
Pls help me here
thanks
geposted Fri 07 Jun 13 @ 6:25 am
Open the setup tab, click on sound setup, leave inputs as none, change outputs as external mixer & soundcard as Numark V7.
geposted Fri 07 Jun 13 @ 8:31 am
Hi
thanks for your reply allready set as that ,but still cannot control volume fader on the software with my mixer
thanks
thanks
geposted Fri 07 Jun 13 @ 9:01 am
....and you never will be able to do that. Your mixer has no MIDI control or USB connection.
You don't need the "virtual" mixer on screen, because you have a real one in front of you!
geposted Fri 07 Jun 13 @ 9:11 am
Hi
Yes i know that ,but when you use the brodcast option do i need to do that manual then ?
thanks
thanks
geposted Fri 07 Jun 13 @ 12:44 pm
See post by beatbreaker below this one.
Here is the wiki link:
click this wiki link
geposted Fri 07 Jun 13 @ 1:33 pm
First off I'm on my phone so no links will be provided.......
What you need to do is setup your decks in the advanced configuration section and under record loopback tell VDJ where it needs to grab the sound from. If you look in the wiki you'll find instructions on how to record with an external mixer which is exactly how you need to set everything up......
So Yes you can broadcast from an external mixer. I used to broadcast 3 different setup that were all plugged into my Allen Heath mixer.
Wiki is your friend........... Good luck.
geposted Fri 07 Jun 13 @ 1:40 pm
