Hi Everybody,
Sounds like a simple question maybe but i cant find it on the forum (clear enough for me) or on the internet.
My goal is to configure virtual DJ as a radio station, so i can broadcast my stream but also can pick up voip calls with Skype and stream it.
I have virtual DJ Pro 7 and a hercules RMX. Is there anyone who can help me out and can explain me in a clear way (maybe figures) how to set this up.
Really a lot of thanks!
geposted Sun 09 Jun 13 @ 5:12 am
It is possible. Done it a thousand times. All you need is, enough soundcards and a USB mixer. Then, you configure Skype to use the soundcard of your choice, set up Skype to use the USB mixer mic. Set up VDJ to "record loop back" and select the USB mixer.
geposted Sun 09 Jun 13 @ 11:03 am
Well i want to use Skype on another PC, my usb mixer is a hercules RMX....so i think i have all i need but it seems i dont get the right configuration.
geposted Sun 09 Jun 13 @ 12:33 pm
I just created this, hope it helps.
[youtube]82K3tLoN3hE&feature=youtu.be[/youtube]
geposted Sun 09 Jun 13 @ 12:39 pm
Tnx a lot for uploading this video. I gonna try and let you know.
Thanks for the effort!!
geposted Sun 09 Jun 13 @ 1:19 pm
Thanks a lot for the upload and effort.
I gonna try!
I gonna try!
geposted Sun 09 Jun 13 @ 1:21 pm
I still don't get it and I have looked at several tutorials. Can someone please help me?
geposted Thu 20 Feb 14 @ 10:17 pm
I still don't get it working.
And i think i have to explain my setting:
- laptop 1 (streaming laptop and using virtual DJ on it)
- Herculex rmx
- laptop 2 i want to use for Skype
- Mic and Headphones are connected to laptop 1
without laptop 2 everything works awesome. Streaming, talking all over air. But now i want to connect laptop 2 to the usb mixer to have the Skype calls to broadcast. Of course i want to use the same headphones and mic as without using Skype.
Is there anyone who can give me a clear picture of how to set it up?
Thank you so much
geposted Thu 03 Jul 14 @ 3:33 am
Have you tried using virtual cables to setup? I have been experimenting with it on sam broadcaster and am now gonna try virtual dj 8 set up as sam works for a bit then stops working properly
geposted Sun 31 Aug 14 @ 4:30 pm
geposted Mon 01 Sep 14 @ 2:07 am
- Herculex rmx
Thank you so much
- Herculex rmx
Thank you so much
if mixer has two mics, u can connect laptop 2 to 2nd mic input
geposted Mon 01 Sep 14 @ 2:08 am
