Hi all,
I'm using this skin for a long time now and I want to share it with you guys.
No play, stop, pause button only the buttons you miss on the rmx controller are on it. Buttons in the skin have other actions then on the controller.
For example the hdc-buttons in the skin shows a pop-up so you can choose the action (or rightclick for activate), the controller buttons will activate them.
The headphone buttons are the select and pfl buttons in 1 button. I have to explain this.
Action in the skin = pfl
Action on the controller = select deck when not selected or pfl when selected on or off.
I have left some space on the top-left for the firetext-administrator-icon.
.jpg)
I use a keyboard too, so created that also. You can download it here.
On top is a panel for some settings. I'm not happy how it looks but it works. Maybe you have some ideas
Best regards,
John
.jpg)
Best regards,
John
geposted Wed 12 Jun 13 @ 1:29 am
Update soon available.
geposted Mon 12 Aug 13 @ 3:00 pm
Looks good. I never been a fan of swapping the browser on top like that. But I do like the layout and colors of the decks you made. Also everything looks easy to find. I will try it out when you release it. Any idea what resolutions you will be releasing?
geposted Mon 12 Aug 13 @ 6:42 pm
Hi,
I have the browser on top because it's easy with touch screens. I can't look trough my hands and arms...
You don't have to wait....
https://virtualdj.com/addons/16001/rmx_extension.html
it's 1024x768 xpl. You can resize it with the skin-resizer-tool if you want.
best regards,
John
best regards,
John
geposted Tue 13 Aug 13 @ 5:20 am
