i have the pioneer wego and sx...i havent used the sx yet cause i dont know if i need to download and run two vdj problems for each controller or can i use one program for both...i saw the config tabs on the new vdj8 but is this possible with 7.4 LE versions?
geposted Wed 12 Jun 13 @ 3:24 am
Hi.
1. There's no LE version for Pioneer DDJ-SX (it comes with SeratoDj)
2. Your Pioneer DDJ WeGo LE version only works with that controller and NO other controller.
3. You CAN use both controllers at the same time with a single program but you will need to upgrade your DDJ-WeGo LE version to VirtualDJ PRO Full. Once you upgrade, you will be able to use whichever controller you wish, or even both at the same time.
4. As a VirtualDJ DDJ WeGo LE version owner you are entitled to 50% discount to upgrade to VirtualDJ PRO Full
5. You can try and see how both units work individually or at the same time by downloading VirtualDJ Home FREE. Home free will allow you to use both controllers for 10 minutes after each launch of the program. If you are satisfied then you can upgrade to PRO FULL
PS: All the above stuff applies to current version, VirtualDJ 7.4
geposted Wed 12 Jun 13 @ 4:09 am
thanks
geposted Fri 14 Jun 13 @ 4:57 pm
