is there a certain number of photos the vdj can handle when using the slideshow option under video when using audio files
geposted Sun 16 Jun 13 @ 2:42 pm
Don't think so, but you can always try and report back here?
...In Some slide show plugin's you will have to reload the folder before any additional pictures are cycled...
geposted Sun 16 Jun 13 @ 6:32 pm
slideshow (Atomix) will auto load when you add pictures to folder, But this olugin, strecthes the image (if the source pic is small). My work around to this one was, I make sure I take my pictures 1920x1080 (thats my second outpu res).
Also, if the pic filesize is over 2MB, you notice a hiccup when palying VIDEO (this happens to me and I did some testing and that was the result. If the files is under 1MB, VIDEO outputs will have no hiiccup.)
slideshow (SBDJ) this will not strecth the picture and does not hiccup when VIDEO is played. The BIG problem is, when you add p[ictures to the folder, it will NOT DISPLAY those pictures. Workaround to this is de-activate and activate.
SBDJ said that he has or had fixed but not updated the download. He was aware of this months and months. I am still waiting for that update. I'm sure he is very busy and I notice that he's putting alot of NEW PLUGIN on the download section.
Crossing fingers for the slideshow plugin.
geposted Mon 17 Jun 13 @ 6:04 am
