i bought a dj4set hercules...and this error message keeps showing i dont know why... and also my headfones dont work...can someone please tell me how config ??
i use the virtual dj LE (4djset)
Thankx
OBS: the erro : http://imageshack.us/a/img23/4175/fb5s.jpg
Thankx
geposted Mon 17 Jun 13 @ 2:09 pm
Did you follow the instructions that came with the product?
I'm sure configuration would be similar to the reset of the Hercules products...Look at the different config's in the wiki (scroll down to Hercules)
https://virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html
geposted Mon 17 Jun 13 @ 2:17 pm
Make sure you have installed the latest hercules drivers.
Now, go to your OS audio settings and make sure that your hercules console is NOT set as default audio device.
If thats the case select you systems built-in audio card as standard device.
Open up VDJ and this error message shouldn't pop up anymore.
geposted Tue 18 Jun 13 @ 8:27 am
