need the red on deck 2 changed to a lighter color the red is very hard to see in daylight & dark when outside
standered VDJ7 4 deck skin 1280 X 1024
Thanks Chris
Thanks Chris
geposted Wed 19 Jun 13 @ 1:40 am
The easiest way to do this would be to edit the bmp for that skin.
(if the skin is inside a zip then unzip the skin & corresponding xml file)
then use a graphic editor.. even paint will work.. but there are tons of free ones out there...
just adjust the colour hue/saturation etc..
If you make a mistake just delete the stuff you extracted and start again... best way to learn :D
geposted Thu 20 Jun 13 @ 4:28 pm
I dont see how such a change in colors would help to see clearly when playing outdoors.
Would recommend a daylight/outdoor skin for that...
https://virtualdj.com/addons/skins.html?category=all&order=default&resolution=all&search=outdoor
geposted Thu 20 Jun 13 @ 10:18 pm
