Forum: VirtualDJ Skins
Topic: skin for numark mixtrack pro 2 - Page: 2
thanks 4 the mix track pro 2 skin downloadlink guys. Nice!!!
maybe you guys should add on the song list option, displays of both decks A&B because you can't see the info of the song that is playing. That would be nice.
NICE! I will download when I get home from work today.
I was waiting for a sweet little skin for the MTP2.
how can i download it??
it says i dont have permission or something like that...
nvm i didnt read something
Norton 360 is claiming that the skin for mixtrack pro II is NOT safe and is deleting the file when downloaded.....anyone know anything about this?
Norton will probably say that for every skin you try to download. Definitely every single Plugin from our Download pages is 100% safe to download and install. Norton (among other antivirus softwares) faulty detect several files as unknown threads, trying to protect your computer.
Usually, there is an option to allow/run anyway, maybe hidden under an icon or a "More" option.
Alternatively, you can temporary disable your Antivirus, install the Plugin/Skin and enable afterwards.
Hello.I want to donwload the skin for mixtrack pro 2,how ican this
can someone please help me to be able to use my mixtrack pro 2 with virtual dj
If you have problems with the controller then you need to explain why it's not working in the first place. Also if this is the case you shouldn't be posting in a forum about the skin for the product. I suggest looking here: http://www.virtualdj.com/forums/140684/PC_Version_Technical_Support/Numark_Mixtrack_Pro_problems_.html?search=mixtrACK%20PRO%202&page=1
This is a link to the original version but it might be able to help. If it doesn't the please use the search function on the forum or start a new topic in an appropriate thread.
If your trying to access this skin then please read here: http://www.virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
Thanks
oi boa tarde comprei uma mixtrack pro II mais nao consigo usala no dj virtual no meu notebook. me ajude pelo amor de Deus.
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the appropriate language forum at the bottom of http://www.virtualdj.com/forums to post in your own language.
Hello, first congratulations for the great and beautiful job you did.
Second, it could do so at 1280x800 resolution?
I tried to convert the tool provided by Virtual, but was buggy.
Grateful.
Hugs.
Try to use the 1440x900 with the Resizer tool and Simple Resize Option. Normally, it shouldnt be a problem to get a 1280x800 skin resolution.
J'aimerais avoir un skin de numark mix track pro 2 pou mon virtual dj
Lovely skin Bob! Thanks djDAD.
There's a minute error on xml file regarding the LED of DECK2 vinyl mode, though it doesn't affect the functionality but could be confusing to the user. Corrected mine and a pretty easy task if a user knows what to do.
PARA LOS QUE TODAVIA SE PREGUNTAN COMO PONER EN FUNCION SU CONTROLADOR NUMARK PRO 2 ES MUY SENCILLO SOLO DESCARGUE EL PLUGIN DE LA PAGINA DE NUMARK Y LUEGO UN TUTORIAL DE COMO MAPEARLA EN GOOGLE Y SERA MUY SENCILLO
55%
