Waddup VDJ Fam,
Being kinda lazy with this one but if this can resolve my issue faster than having to read through the mapping manual (which I'm doing atm) -
awesome.
I'm trying to work out a mapping code that will enable my 'clone_deck' key to clone only to the current deck selected at that time ??
Example - A Deck is playing and I want to clone B Deck but, for reasons unknown to me, it will clone them all or B / C / D individually at random.
I guess what I'm really asking is if there's a way for A Deck to clone only to B Deck and the same with C to D.
Any feedback would be much appreciated.
Cheers !
awesome.
Cheers !
geposted Fri 28 Jun 13 @ 11:29 pm
deck 1 clone_deck 2 & deck 1 clone_deck 3 & deck 1 clone_deck 4.
It's not dynamic but will do what you ask. if you want it to copy the master deck to all other decks you could try something like this
deck 1 masterdeck ? deck 1 clone_deck 2 & deck 1 clone_deck 3 & deck 1 clone_deck 4 : deck 2 masterdeck ? deck 2 clone_deck 1 & deck 1 clone_deck 3 & deck 1 clone_deck 4 : deck 3 masterdeck ? deck 3 clone_deck 1 & deck 2 clone_deck 4 & deck 1 clone_deck 4 : deck 4 masterdeck ? deck 4 clone_deck 1 & deck 2 clone_deck 3 & deck 1 clone_deck 4 : nothing
all it does is ask what the master deck is currently set as and copies the track to all other decks. I'm not sure how this would be useful to have all the decks the same, but there it is. VDJ script can do almost anything you can think of.
geposted Sat 29 Jun 13 @ 12:28 am
there was a mistake in the pattern.. this should fix it.
deck 1 masterdeck ? deck 1 clone_deck 2 & deck 1 clone_deck 3 & deck 1 clone_deck 4 : deck 2 masterdeck ? deck 2 clone_deck 1 & deck 2 clone_deck 3 & deck 2 clone_deck 4 : deck 3 masterdeck ? deck 3 clone_deck 1 & deck 3 clone_deck 2 & deck 3 clone_deck 4 : deck 4 masterdeck ? deck 4 clone_deck 1 & deck 4 clone_deck 2 & deck 4 clone_deck 3 : nothing
geposted Sat 29 Jun 13 @ 6:13 am
Hey mate thanks for the feedback, will give this a go tonight and re-post the results
geposted Wed 14 Aug 13 @ 7:42 pm
What about cloning deck 1 to deck 3 and deck 2 to deck 4 using the pause button what would that look like?
geposted Wed 05 Feb 14 @ 1:48 am
deck 1 clone_deck 3 & deck 2 clone_deck 4
geposted Wed 05 Feb 14 @ 2:36 am
