Hi, wondering if any of you vdj skin geniuses can help on this one, I've got a ddj sx and I'm using the ddj sx skin which I downloaded. My issue is trying to map the "panel control" button on the controller to switch between the "battle and "full" skins. I can do this just fine using a mouse using the existing tab on the skin but cannot figure out how to map a button to do so. Any ideas anyone???
geposted Sun 30 Jun 13 @ 2:24 am
Please don't post the same question more than once.
You have also asked this amongst others in the following topic, where you can find an answer:
https://virtualdj.com/forums/173767/VirtualDJ_Skins/_NEW__Pioneer_DDJ-SX.html
NOTE: Questions about mapping should be asked in the PC or Mac technical support forums (As appropriate for the type of computer you are using.)
[Duplicate topic closed]
geposted Sun 30 Jun 13 @ 11:10 am
