Printed up the transfer instructions....
Ported over all music
Copied the Virtual DJ Documents directory for database description.
All ok.
Opened VDJ, reloaded my skin (it was there).
But, the layout of the skin, Samples, etc are not there. There's one sample I need very badly.
Is there another file name somewhere that keeps track of that stuff?
Thanks,
Doug
PS: The Doc directory that copied over lists the sample, but it isn't there when the program runs...
All ok.
Thanks,
Doug
geposted Sun 30 Jun 13 @ 10:29 am
Paths of loaded (custom) samples are saved in the registries, so you will need to reload them.
geposted Sun 30 Jun 13 @ 9:48 pm
Aha! Well, that was easy. Thanks!
geposted Mon 01 Jul 13 @ 4:42 am
