I'm running VDJ Pro, with time codes (American Audio MXR 14 mixer, tech1200's, serato CV2). My PC laptop specs are Win 7 with 4 GB of RAM. Dont have any problems with anything other than one thing....
If I do a 4 or 8 bar loop at the beginning of a song, when I let go of the vinyl/platter, the song doesnt loop where I started it. Instead, it jumps right back to the beginning of the track. Any ideas on how to make it loop when I let go of the vinyl at the exact spot where I wanted it to start looping?
geposted Mon 01 Jul 13 @ 2:32 pm
So you cue your song, hold the record, hit loop, let go and it drops back to the beginning of the track?
Mine doesn't work that way at all. Sounds like fader start is on.
geposted Mon 01 Jul 13 @ 11:05 pm
This is what I can't understand:
Surely if you make a loop at the beginning of a track, it will start from the beginning.
Where are you expecting it to start from?
geposted Tue 02 Jul 13 @ 4:16 am
Any chance you're using your TCV in "ABSOLUT" mode ?
geposted Tue 02 Jul 13 @ 4:55 am
Exactly! Except the loop turns off when it jumps back to the beginning of the track. And the mixer doesnt have a fader start feature on it, as far as I can tell.
Example...track has a 16 bar intro beat. I start the loop with a 4 or 8 bar loop before the vocals come in, so its about 10 seconds into the track already. When I let go of the platter, the loop turns off and it goes directly back to the beginning of the track.
Nope...its in smart relative mode.
Not sure if it matters, but I'm completely up to date, at version 7.4 Also, I can loop normally too. So if the track is playing and I just hit the 4 or 8 bar loop, its ok. It only jumps back to the beginning of the track if I'm holding the vinyl (cueing), hit the loop, and then let go.
geposted Tue 02 Jul 13 @ 9:14 am
Ah, right. So when you said the loop was at the beginning, you didn't actually mean the beginning. :-P
geposted Tue 02 Jul 13 @ 10:04 am
Messed with some settings and its still doing it. Doesnt do it though when I use a controller.
geposted Wed 03 Jul 13 @ 5:48 pm
Hi, I uses d same mixer buh with denon dns3500. My question is how do I record my mix? Thanks.
geposted Tue 13 Aug 13 @ 3:56 am
Please see https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
NOTE: If you wish to use your Denon DNS3500 to control VirtualDJ via timecode, then you will need to upgrade to the full VirtualDJ Professional at a discount: https://virtualdj.com/buy/
geposted Tue 13 Aug 13 @ 7:18 am
