How do you configure the hercules dj console rmx with virtual dj 7? I see a bunch of people using VDJ 7 with the console. I would like to be able to use VDJ 7 as well. I currently use the VDJ LE version. Do I need a sound card? Or any extra equipment? Someone please help me out.
geposted Tue 02 Jul 13 @ 11:12 pm
The RMX works great with VDJ7. All you need is this....
https://virtualdj.com/buy/
If you purchased youre console new then register it to recieve a 50% discount.
https://virtualdj.com/users/edit.html
geposted Tue 02 Jul 13 @ 11:22 pm
Does that mean I have to use all 4 decks?
geposted Wed 03 Jul 13 @ 2:59 pm
No, you can use two or four.
geposted Wed 03 Jul 13 @ 3:39 pm
Ok, here is the truth.. I have send thousands on controllers. I like the rmx with my other midi controlers for the extras. the ability to use it in virtual dj 7 allows you to make buttons do other things and also the sound card in it is able to handle anything you throw at it.. I bought a s4 and sold it less then 4 days later as it wasn't as good as the combos of gear im using at the fraction of the price. If you have issues pm me and IM happy to walk you through it all
geposted Mon 08 Jul 13 @ 12:33 am
