please help.
i need to show the cover art and the song title and artist for a performance.
i know in the past there was the fx titler. which was pretty awesome. now i guess it is gone. please advise.
i have tried to install showcover by dj cel without success. please advise.
i have read the forums and have found nothing useful.
thanks for all the help.
geposted Fri 05 Jul 13 @ 8:33 pm
I use the showcover by djcell too.
You just need to load the art from songs/id3 tag manually.
geposted Fri 05 Jul 13 @ 10:19 pm
Ashampoo cover finder might be worth a look. Not used it but saw a video and it looks quite good
geposted Sat 06 Jul 13 @ 6:43 am
they have the cover, and they have the attached file.
but it still won't work.
please advise. i need this working by thursday night.
geposted Wed 10 Jul 13 @ 1:56 am
You say you can't install show cover, why not? Also check to see if your other video plugins work. Do you have the latest directx drivers?
geposted Wed 10 Jul 13 @ 11:10 am
perhaps someone should make a tool to validate and covers to files in bulk. one that would make sure everything is ready to go and would work much faster than virtual dj allows us to. adding covers to files 1 by 1 is so time consuming.
geposted Wed 17 Jul 13 @ 11:26 am
This is another issue, did you get your first issue resolved? As far as I know, the covers are added automatically, if there is a cover.
geposted Wed 17 Jul 13 @ 11:40 am
the cover is there. my issue is that i do not want to create an image for each file separately. i want virtual dj to get the cover art from the id3 tag of the active deck and just show that. i wish it could be that simple
enable / disable
show from: active or automix
fade: 0,1,2,3
horizontal alignment: right, center, left
vertical alignment: top, center, bottom
image: original size, stretch to fit
capture from: from vdj tag, file tag (id3)
transition: fade, swap, use video transition
enable / disable
fade: 0,1,2,3
geposted Thu 18 Jul 13 @ 12:55 am
Unusual this, but Mac users can show covers from tags. I haven't ported the relevant plugin to PC yet.
geposted Thu 18 Jul 13 @ 6:24 am
djkz, I know its a pain to load it 1 by 1, but right at this time it's the only option we have.
For me, I only use the covers when I need to remotely load the next song so I can see on the screen that it did load (tiny cover on the left/down corner) so I know for sure the next song is good to go (play).
Maybe one day (a fix) will load the covers (if covers exist) automatically.
geposted Thu 18 Jul 13 @ 10:49 am
The way I see it. Cover and id3 tags and video effect is a virtualdj element not a video effect. But that's just me
geposted Thu 18 Jul 13 @ 1:56 pm
