Topic: Sort Order
Is there a way to sort a playlist by bpm first them Key or vice versa?
I did a search but didn't see any questions like this.
I ask because I have set up a long playlist for auto mix to play at my cousins wedding for just background music for cocktail / Dinner, then I will get up and turn it off and go to work with what I need to do.
Brendan
geposted Sat 06 Jul 13 @ 2:32 am
You can already sort by both columns, just click one then the other, if you sort by BPM then Key you will have a list sorted primarily by key, but withing in the key codes you will have the tracks ordered by bpm.
Similarly if you sort first by Key then BPM you will sort primarily by BPM, but within each BPM it will be sorted by Key's. This second way is harder to manage IMO and not as important as the first way because you should be comfortable matching the BPM withing about +/- 6bpm without ever stressing your computer, and the range of BPM's being a decimal is much higher than just 12 keys
Thanks.
Brendan
