Hi,
Can someone enlighten me on how to map a button to fast forward by four regular beats (as well as rewind)? I'd like to cycle through tracks without losing the time. I have a Denon DJ MC300 if that makes any difference.
Quite new to the whole mapping scene as I've just been using the stock mappings for a while.
Many thanks
Many thanks
geposted Wed 10 Jul 13 @ 1:13 pm
the_smelly_smurf wrote :
Hi,
Many thanks
Many thanks
From the VDJscript verbs in VirtualDJ page.
Looks like goto is what you want to use
goto : change the position in the song. 'goto +10ms' jumps 10ms forward. 'goto -4' jumps 4 beats backward. 'goto 20%' goes at 20% of the song's length.
So for your example you'd want 2 buttons or one button mapped with a shift function to toggle FWD/RWD to:
For forward 4 beats use:
goto +4
And for reverse 4 beats use:
goto -4
geposted Wed 10 Jul 13 @ 2:13 pm
almost....
If you are using a midi device you will also need to use 'repeat' to repeat the action at a set interval as long as you have the button pressed
repeat 100ms & goto +4
repeat 100ms & goto -4
you can also include a delay before the button will start repeating with another parameter eg.
repeat 100ms 500ms & goto +4
This will work the first time you hit the button, but will pause for half a second before repeating the action every tenth of a second.
geposted Wed 10 Jul 13 @ 2:31 pm
Thanks a lot guys, really helped!
geposted Wed 10 Jul 13 @ 5:10 pm
