Topic: DDJ_WEGO
Hi Guys
Im having trouble getting downloaded effect working, I have done the process of download, put into Sound effects file but it still doesn't work, it won't even show up on my virtual dj. What can i do? P.S I am a Mac User
Thanks
geposted Fri 12 Jul 13 @ 11:19 am
VirtualDJ LE is limited software and doesn't support using custom effects outside of the 20 day Pro trial. If your trial has expired then you will need to upgrade to the full VirtualDJ Professional at a discount to be able to use custom effects, skins and much, much more: https://virtualdj.com/buy/
If your trial is still active, then please ensure that you are installing the effect correctly in the correct location: https://virtualdj.com/wiki/How%20do%20I%20download%20and%20install%20new%20plugins.html
