VDJ7, mixtrack pro II, windows 7 pro 64bit
sound config is:
1st settings:
inputs: none
outputs: Master: chan 1&2/headphones chan 3&4
Sound Card: Numark
2nd settings:
inputs: none
outputs: Master: when sound card is changed to 4.1 I now have 3 options for routing the sound, have tried all 3
Sound Card: 4.1 when selected I also now have 3 options for routing the sound, have tried all three.
with either the above configurations selected my sound is not mapping correctly. with deck fader down, master down sound is still outputted, if I select the "cue" button either a or b the sound either lowers or gains, I can adjust the sound with the headphone volume knob.
this issue happened from time to time with my original Mixtrack Pro, it happened last week with my new mixtrack pro II, I had to plug into a usb I havent had it plugged into previously, almost as if it needed to see a new hardware install.
sound config is:
1st settings:
inputs: none
Sound Card: Numark
2nd settings:
inputs: none
geposted Sun 14 Jul 13 @ 9:55 am
here is a perfect example, I just switched USB ports and now it works fine. rebooted laptop and still working, hopefully it stays.
geposted Sun 14 Jul 13 @ 10:18 am
Which version of vdj do you use exactly. See under config/ info
geposted Sun 14 Jul 13 @ 1:41 pm
7.4 b453
Thanks.
Thanks.
geposted Sun 14 Jul 13 @ 4:00 pm
