Hi all,
i'm really into this dj thing now and this is one of the 1st few mix i actually did.
just wanna get some useful comments to help me improve further.
Thanks in advance
here's the Link: https://soundcloud.com/oryul_90/the-emergency-mixdown
Thanks in advance
geposted Sun 14 Jul 13 @ 11:14 am
anyone?
geposted Mon 15 Jul 13 @ 1:03 pm
man this forum is so dead
geposted Tue 16 Jul 13 @ 1:00 pm
Decent mix! I like it! I'm new to the dj world myself, keep up the good work!
geposted Fri 26 Jul 13 @ 1:06 am
Will listen to it, I'll let you know something when I've checked i out.......
geposted Sat 03 Aug 13 @ 6:40 am
Hi there,
I checked out your mix, you've got quite a few plays and likes so you're clearly onto something good. I can't really comment though, the music isn't my scene.
Happy mixing
Vernski
Happy mixing
Vernski
geposted Sat 14 Sep 13 @ 8:21 am
The way you mixed those first 2 tracks was not smooth at all bro. lol. But hey, you gotta start somewhere and i'll give you props for putting together such a long mix for it being one of your first mixes.
I do not have much experience putting together such a long mix but I have heard some really mixes from clubkillers.com. I hear those Djs mix and then I guide myself from there. Here's what I've picked up from listening to those mixes:
-Use your hot cues! (Cues are there for a reason that is to chop up the song. Have fun with it and don't simply play the song from beginning to end or let it run continuously from any given point to another! Have fun with it!)
-bring in some crazy shit from youtube such as newscasts, cartoons, tv shows, etc. Get creative!
-know your music and have many songs to choose from because you won't be playing the song the entire 3-4 minutes!
-use effects and samples.
-Finally, just have fun with it and enjoy yourself!
geposted Wed 02 Oct 13 @ 1:17 am
I'll be a bit more specific. Your mixing is off key.
In other words, when you blend two tracks, the music from each is clashing. The tracks are out of tune with each other.
If you haven't done so already, I suggest you enable the display of key data in the VDJ browser.
Alongside each analysed track you'll see either an number/letter combination (eg 7B) or just letters (eg Cm) that can be used to determine which tracks will fit musically with others. Look up info on the Camelot wheel and mixing in key.
Mixing tracks that are not in key makes for painful listening!
geposted Wed 02 Oct 13 @ 3:58 am
thanks for the helpful comment will take that in mind anyway i did something creative like you said and add snippets of despicable me audio to my other track.
do let me know what you think.
https://soundcloud.com/oryul_90/babybananabot-mix
geposted Wed 02 Oct 13 @ 10:41 am
thank you jmavila02 and groovindj for the useful tips. will keep em in mind
geposted Wed 02 Oct 13 @ 10:44 am
