When I do wedding, during dinner I make a playlist and I set it to auto play.
The other night I was letting my list auto play from the playlist that I had created, about 40 minutes into the playlist I wanted to check which songs were coming next. I accidentally hit the artist button on the playlist. The playlist was all rearranged now to artist from a to z. I didn't want to play 4 Frank Sinatra songs in a row so I rearranged the entire playlist again while it was playing.
So my question is if this happens in the future is there anyway to get the playlist back to the original order I had before I hit the button.
Would I have to stop the auto play and reload the playlist then just remove the songs already played.
The other problem I had with this and the reason I would like find out how to fix this is - If I load a previously created playlist then as I find out what types of music people are into I will search for more songs of that type of music then load them into the playlist so that I always have plenty of music readily available. So in essence I have a playlist that is not saved cause I have been adding to a list that was created earlier. If I hit the artist button on top of the playlist that I have been adding to it screws the whole thing up. So if anyone know how to undo what was done when I hit the Artist button that would be greatly appreciated
Thanks
Derek
Thanks
Derek
geposted Sun 14 Jul 13 @ 7:57 pm
Usually when I AUTOPLAY a SAVED Playlist, I check the AUTO REMOVE PLAYED so that it clears the LIST and of course you know what song is also next in line without touching anything.
In over all, I haven't see or know any UNDO that you are looking for.
geposted Sun 14 Jul 13 @ 8:35 pm
Hi, I've created similar posts to yours and added a suggestion in Wishlist for the next version. It's a tough break if you place a lot of importance on the order of your Playlist and then with one click it's all undone! For a while I thought clicking on the top of the left hand column resorted back to your custom arranged order, but I think it is for most recently played.?
geposted Mon 15 Jul 13 @ 6:59 pm
