Yes, I need help!!!
On a panel, visible="get loop & param_equal 2 ? on : off" WORKS.
However visible="get loop & param_equal 0.25 ? on : off" DOES NOT work...
Any thoughts?
Any thoughts?
geposted Tue 16 Jul 13 @ 1:04 am
I think it only returns an integer as even on a skins textzone it willl show '...' for anything under 1 beat... You could always just use
loop 0.25 ? on : off
or you could get tricky and do something like this to have an on and off state for each size
pannel1 = loop_select 0.25 ? loop ? on : off : off
pannel2 = loop_select 0.25 ? loop ? off : on : off
geposted Tue 16 Jul 13 @ 1:37 am
No. "get loop" will actually return text, that when casted to numeric will result to integer.
However loop_select 0.125 ? on : off works like a charm!
Thanks!
PS: I wanted the panel to be visible depending on the selected loop size even when the deck is not in a loop. Otherwise loop 0.125 ? on : off would work ;)
Thanks!
geposted Tue 16 Jul 13 @ 1:59 am
geposted Tue 16 Jul 13 @ 8:50 am
