Bonjour tous ,
J'ai un soucis avec le cross fader de ma console RMX de chez hercule, je ne peux plus changer de platine (A à B) le cross tremble dans Virtual dj
si quelqu'un a eu se souci ce serai cool de votre part
si c'est le cross à changer es que ca vaut de coup? tarif ou bien site web
pilote désinstaller puis mis à jour
Pilote mis a jour
Virtual dj 5.2.2
Merci bonne Soirée à tous
Pilote mis a jour
Virtual dj 5.2.2
geposted Tue 16 Jul 13 @ 10:11 am
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the correct language forum: https://virtualdj.com/forums/29/French_Forum.html
geposted Tue 16 Jul 13 @ 10:16 am
Hello all,
I have problems with the cross fader from my Hercules RMX to home, I can not change platinum (A to B) cross tremble in Virtual DJ
if anyone has had to worry would be cool of you
if the cross to change are that it's worth the shot? rate or website
Driver uninstall and updated
Driver updated
Virtual DJ 5.2.2
geposted Tue 16 Jul 13 @ 10:25 am
Its hard to understand by the language barrier but i see you are having crossfader problems. Try using the recommended contact cleaning spray as described this wiki note.https://virtualdj.com/wiki/Slider%20on%20MIDI%20controller%20works%20erratically.html
geposted Tue 16 Jul 13 @ 9:33 pm
