For two days I have been playing with the numark dj2go with djio last night I played for hours and the "sync" worked as normal, either the buttons on the dj2go or the bottons on the skin would adjust/match bpms and like I said it worked great.
Tonight after a few hours of auto mix I started playing and now none of the sync buttons will work, the ones on the dj2go flash if a songs playing, and the skin button shows you are pushing it but the bpms stay the same neither side will change to match the other.
The sliders will allow manual bpm changes.
I have tried running repair and restarting and it might work once or none on a program restart, so it's still got some issue.
I do not believe I hit any settings that would lock sync.
Many thanks for any help
Cheers,
P.
Cheers,
P.
geposted Wed 17 Jul 13 @ 6:37 am
I removed the dj2go and djio and ran it just program on laptop and the sync buttons on the skin show you click them but do not adjust bpm?
what is up? I hsve been using this program for years with no issues like this
geposted Wed 17 Jul 13 @ 7:19 am
Are you using a 4 deck skin? If so, please see https://virtualdj.com/wiki/Masterdeck.html
geposted Wed 17 Jul 13 @ 7:40 am
no two deck...okay this is a doh on me moment.....wife fixed it, I was trying to do syncs that were outside the sync range setting,
as soon as I found that all was well.....
geposted Thu 18 Jul 13 @ 5:08 am
