Topic: KEYBOARD MAPPING
Hi Can anybody tell me why I can't map everything on my keyboard?
I have made my keyboard play the decks and select the deck, but it will not let me program it to use the fader from the keyboard niether the tone controls. If Anyone understands what I'm trying to ask?
Also, If I am playing a pre-planned playlist, I lose the playlist if I click on something else on the left. How can I keep the plalist where I want it in the order I want it?
I hope you all understand what I'm asking.
geposted Wed 17 Jul 13 @ 10:23 am
Not sure about the mapping if it's because (HOME VERSION) might be limited (dunno).
But use the KEY LEARN and ACTION LEARN. Maybe someone understand exactly what you want to do and give you the exact command.
For the Playlist:
When you have saved your playlist and selected it, it will be displayed on the playlist window, but if you don't play or add anything to that list and click somewhere else (left window), it will dissapear.
Just add a song so it won't dissapear, you can alway removed that added song afterwards and the list will not go away.
Just define a key with the action: volume +1
That should increase the volume fader of the selected deck each time you press the key (or is been triggered by the keyboard if you hold it)
To decrease: volume -1
Same goes for eq_low +1 / -1, eq_mid, eq_high
Play with the +1 values a little bit. Maybe +5 suits better for you.
Thanx guys but I have tried all that now. Still don't make the sliders or Tones work. Maybe like to the other guy said, the free Home might be limited. Thanx Again
Did you activate the "use keyboard shortcuts" function...? Should also work with the Home Free Version...
You may also need to add the deck number to the mapping, e.g: deck 1 eq_low +1
Otherwise, it will apply to the deck that you currently have selected (I.e: The one that you are pre-listening to.)
Or you could use deck active eq_low +1 to apply it to the active deck (The one that VirtualDJ considers playing live.)
For further information about mapping keyboard shortcuts, please see: https://virtualdj.com/wiki/How%20do%20I%20map%20a%20keyboard%20shortcut.html
Les touche ki son deja active
como consigo o arquivo keyboard mapping.xmi?
Por favorn intente nuestro foro espanol aqui gracias.
