i have a problem i try to record but i cant says: *Record Error* Cant open"the place where i want to save".waw i cant set the configurations change the format .waw to .mp3 i have no way to change please HELP ME!
thanks
thanks
geposted Fri 19 Jul 13 @ 12:52 am
thanks
thanks
The Limited Edition (LE version) is only allowing you to record in wav format. No encoder is needed. The error you receive is probably related to user's permissions. Try to choose to record to an external Hard Drive and see if that helps.
Make sure you are admin in your computer. Or rightclick on the VirtualDJ LE icon on yoru desktop and choose to Run as Admin to see if that changes anything.
geposted Fri 19 Jul 13 @ 2:30 pm
