Hi,
I have VDJ Pro and have bought a Numark N4.
VDJ isn't automatically recognising the N4 (even though I have added the N4 mapper file) so I'm mapping manually.
Everything has mapped fine except fro the jogwheels.
When I learn a new key the jogwheels themselves register as key but I can't manage to map them. I've tried:
Action-Learn then clicking on the appropriate deck's jogwheel.
Using "jogwheel", "touchwheel" "deck left jogwheel" etc as commands written in manually.
I've also checked the VDJ Script page to make sure the commands I'm using are correct :/
But I atill can;t get them to work!
Please help, any advice appreciated.
geposted Thu 25 Jul 13 @ 6:39 pm
first register your serial so you can update to the latest version It will work natively. next reset your mapper back to default by hitting the button with a disk on it at the bottom of the mapper page. If that doesn't work you should only have to map 'touchwheel' and 'touchwheel_touch'
To make sure you are getting the correct messages, hold your hand on the jogwheel, then press action learn and move the jog to get the CC of the jog not the note of the touchpad
geposted Thu 25 Jul 13 @ 6:45 pm
