Ok so Im really new to using midi with VDJ,
Up to now I have been using time codes with Numark Cdj's and the jog-wheel when used on the outside like normal would pitch bend the track for me, and of course release back after i stopped moving the Jog-wheel.
I have used the mapper for the Traktor controller s4 for a day now, and everything works perfectly, except at the current map when I use the outside of the Jogwheel its scratching rather than pitch bending.
I have tried a few options and nothing seems to be working for me,
I hope I have explained well enough, again very new to this, and would really really appreciate if anyone could help perhaps with the correct script I need to get this working!
Regards
Shane
Regards
Shane
geposted Tue 30 Jul 13 @ 5:22 am
It sounds like it's a hardware issue as the S4 is pressure sensitive not touch sensitive like most other controllers.
As a workaround you could disable vinyl mode by mapping this to a button
vinyl_mode 0
or you can disable scratching completely by changing the mapping of the jog from 'touchwheel' to 'jogwheel'.
vinyl_mode 0
geposted Tue 30 Jul 13 @ 6:29 am
