What speaker is better the American audio pxw 18p or db 808d ??
geposted Tue 30 Jul 13 @ 5:17 pm
What cola is better? Coke or Pepsi? :-)
What jeans are better? Levi's or Wrangler?
The important thing is which one do you prefer? Which one is best for your needs? No one else has your needs, only you do.
It's difficult to say which sub is "better" by specs alone, because neither spec list goes into much detail.
The best way to compare is to listen to both, side by side, switched from one to the other and back again, while listening to a track you know well.
geposted Tue 30 Jul 13 @ 5:27 pm
The DB technologies is a better brand but, the subwoofer looks kind of small on picture. I like that its compact like a QSC Kw181 sub. It also weighs 74 pounds compared to 187 lbs on the American audio. If you want to be in a Budget of the American Audio price range, I would get This.. http://www.guitarcenter.com/Harbinger-1000W-Subwoofer-with-BBE-processing-107928681-i2524855.gc
I heard the HP 118s rated at 700 watts and they sounded really good. This new model is 1000 watts plus, it has a BBE sound maximize. you cant go wrong for 699.
geposted Wed 31 Jul 13 @ 1:35 am
RCF, FBT,QSC and Yorkville
geposted Wed 31 Jul 13 @ 9:36 am
